Date/Time: Tue, 24 Nov 2026 17:08:59 +0000
custom studies not working
View Count: 2646
[2019-05-22 08:10:53]
User740709 - Posts: 159
After a recent update my custom studies stopped working. I am using 32bit version. I read that I should recompile them but I have .dll and SC just says "...not supported".
I am attaching the study that I would need most. Is it possible for you to have a look at it?
I would appreciate it.
Thank you very much.
Kind regards,
Hana
Private File
[2019-05-22 16:01:42]
You may need to run the 32-bit version of Sierra Chart:
How to Use an Advanced Custom Study or a Study Collection: Custom Study Not Listed or Not Displaying on Chart
[2019-05-22 16:16:08]
Thanks for your answer.
As I mentioned in my previous message, I am using 32-bit version but the .dll does not work.
Is there any way how to solve it?
Thanks.
Regards,
Hana
[2019-05-23 03:59:05]
You really need the developer to rebuild the custom study for the current version of Sierra Chart.
[2019-05-23 07:11:48]
OK, I am reverting back to previous version.
I do not know the developer as I downloaded this from your forum very long time ago.
So, since I have no contact with him/her, is there any chance that you could please develop the following study in SC? I am not a developer myself and do not have any contacts. This study seems relatively easy (to me, I cannot really assess). It is used with Numbers Bars and it could plot either real time or after the bar is completed.
The feature is as follows:
In numbers bar, plot (for example) a dash at the price leve where ask/bid/delta/volume is in the range from (a number) to (a number).
I am attaching a screenshot of the settings. There are 6 variables as inputs.
I am sorry for asking you to develop a study but maybe someone else could benefit from it and since I downloaded in your forum it can be a part of SC.
Thank you in advance.
Kind regards,
Hana
imagestudy.png / V - Attached On 2019-05-23 07:11:23 UTC - Size: 41.3 KB - 730 views
[2019-05-23 07:30:24]
Ackin - Posts: 1866
similar study is SCH default study: Volume At Price Threshold Alert V2
Volume at Price Threshold Alert V2
but your study is not difficult to recode (max 1 hour).
If you want, register on CZ forum (free) and I'll do it for you. It will be ready for download at night.
more info:
Ackin's indicators (SCH users requests for studies) - Update list | Post: 178661
