Date/Time: Fri, 26 Apr 2024 07:40:17 +0000
Exporting Historical Data
View Count: 1456
[2019-05-16 04:09:23] |
Yes.
[2020-02-04 08:24:03] |
kremat0r - Posts: 41 |
Hi team, Please tell me how to download data with specific days name included in txt file? I know how to download historical daily data, but there is only a "Date number". I tried to change it to intraday charts only , with: The option is Chart >> Chart Settings >> Advanced Settings >> Display Day Of Week With Dates On Intraday Chart Time Scale"
but even with this option data exported to file has only column with date, time OHLC, volume etc. Please help me :) EDIT 10:21 I used a excel formula to put day names, but it will be faster if it comes directly from sierra. Date Time Of Last Edit: 2020-02-04 09:22:12
[2020-02-04 10:53:15] |
We are not understanding this. However, it is not possible to include any day name within the chart data file. For instructions to export data, refer to this page: Exporting and Importing Intraday Data Files We cannot provide any further help here. If the export capabilities you are looking for are not supported, then they are not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
