Date/Time: Tue, 03 Nov 2026 14:27:26 +0000
Protobuf file outdated?
View Count: 1112
[2019-05-14 02:37:26]
bfreis - Posts: 19
Are the protobuf files outdated?
Reason I ask is because:
(1) The protobuf file is a "V3" file, but apparently the protocol is a "v8" (not sure they should match, though); and
(2) More importantly, I'm receiving messages with fields that are not defined on the proto file!
In the proto file I got from Github, the message PositionUpdate has 11 fields:
  int32 RequestID = 1;
  int32 TotalNumberMessages = 2;
  int32 MessageNumber = 3;
  string Symbol = 4;
  string Exchange = 5;
  double Quantity = 6;
  double AveragePrice = 7;
  string PositionIdentifier = 8;
  string TradeAccount = 9;
  uint32 NoPositions = 10;
  uint32 Unsolicited = 11;
However, I'm receiving a message fields tag 12 and 13:
TotalNumberMessages: 1
MessageNumber: 1
Symbol: "ES-FOP-20190517-2810-P-GLOBEX-50-USD"
Quantity: 3
AveragePrice: 27.111733333000004
TradeAccount: "XXXXXXX"
Unsolicited: 1
/* 11 unknown bytes */
12: 0
13: 0
Any ideas?
[2019-05-14 03:20:49]
bfreis - Posts: 19
I found a different proto file that has those 2 extra fields. It also contain a lot of other changes compared to the file on Github.
http://dtcprotocol.org/DTC_Files/DTCProtocol.GPBV3.proto
So it's safe to say that the file on Github is badly outdated.
Anyways, problem solved. Hopefully this can help others.
[2019-05-14 04:02:21]
Yes
[2019-05-14 05:57:43]
Version 3 refers to Google protocol buffers version 3. Version 8 refers to the DTC protocol version.
