Date/Time: Wed, 25 Nov 2026 12:49:14 +0000
synchronize drawing
View Count: 3462
| [2019-05-08 04:07:40] |
| User633898 - Posts: 32 |
Hi, Can you please advise how to synchronize the drawing in multiple charts within a file? Thanks |
| [2019-05-08 16:19:17] |
We are not sure exactly what you are asking, but our best guess is that you want to know how to copy drawings from one chart to another. Refer to the following for information on how to do this: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-08-04 12:55:18] |
| HerculesT41 - Posts: 16 |
Is there a setting somewhere to sync drawing at chartbook level(something like "sync drawings for all charts in chartbook"?) kind of universal switch. I have 6 charts in my chartbook and i don't want to go in settings of each of them and put chart numbers of remaining charts in chartbook. i looked through drawing sync documentation but not able to find any setting so far. |
| [2021-08-04 15:13:41] |
| John - SC Support - Posts: 48648 |
There is nothing like what you are asking. The only way to do it is to put the information into each chart for which other charts you want to copy the data from. Refer to the information here: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
