Date/Time: Wed, 18 Nov 2026 16:12:16 +0000
DATA
View Count: 831
| [2019-05-01 11:20:52] |
| Robert Wojczak - Posts: 178 |
If I want to get CME futuers data and dont have a brokerage account to use to get the cheaper data. Then I would need the SC Data feed for $35 my SC package 5 for $36 and for nymex $115.50 Thank you |
| [2019-05-01 13:20:50] |
Yes but for the real-time data feed connection you can use the option for 20 symbols for 25 a month. And in a couple of months, that limitation with symbols will be removed or increased.
