Date/Time: Sun, 01 Nov 2026 09:47:11 +0000
Gann HiLo Indictor (NOT FAN, the line)
View Count: 2750
| [2019-04-26 21:19:39] |
| User160486 - Posts: 42 |
Do you have a Gann HiLo indictor or an alternative to it? I am having trouble finding it and I heavily rely on it. Please advise. Thanks, C
| [2019-04-26 23:21:13] |
Is this what you are looking for?: https://www.prorealcode.com/prorealtime-indicators/gann-hilo-activator/ If so we can put this in quickly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-26 23:21:26
| [2019-04-26 23:30:07] |
Yes, please. That would be great. Your fast customer service is great. Thanks again.
| [2019-04-26 23:31:24] |
We should have this out next week.
| [2019-04-26 23:44:11] |
This is the Gann HI LOW ACTIVATOR The actual original value is 3 but I put it at 12 or 11 and provides fantastic reversal possibility, combined with 2 other indicators to confirm and pin point entry timing it has gave me great results. |
| Private File |
| [2019-04-30 19:30:41] |
Just wanted to check in with you, when do you think you will have the Gann indicator out?
| [2019-04-30 19:38:18] |
It should be out this week.
| [2019-05-06 23:53:29] |
I wanted to see how you were coming along with the Gann indicator. When should it be out?
| [2019-05-07 01:21:15] |
| ertrader - Posts: 698 |
I'm seeing it in V 1915
| [2019-05-07 01:34:30] |
Yes this is now available in the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-12-30 18:45:58] |
| User90125 - Posts: 715 |
Was the source code (.cpp) ever released for this - Gann HiLo Activator?
| [2021-12-31 15:09:12] |
| John - SC Support - Posts: 48377 |
The source code for that specific study is in the file Studies2.cpp which is located in the ACS_Source folder which is located under your main Sierra Chart installation folder. Refer to the following for how to search for source code for the studies in Sierra Chart: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
