Date/Time: Sat, 17 Oct 2026 06:52:03 +0000
auto-trade not activating
View Count: 1024
| [2019-04-17 18:16:52] |
| User996274 - Posts: 96 |
Last couple days the auto trade feature (studies) has not entered or closed when signal met or reversed when said close was activated (manually) there are no errors in my log and I have used this system since the beginning of the year w/o issue Also, it appears not to be isolated to 1888 as I have it on an early version as well This has been problematic to say the least and costly FWIW they are also on 2 different data feeds and brokers (CQG and IB) Date Time Of Last Edit: 2019-04-17 20:22:58
| [2019-04-18 00:09:57] |
Is this trading system using ACSIL or the Spreadsheet System for Trading study?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-18 00:10:11
| [2019-04-18 00:29:07] |
Studies "Trading system based on alert condition" |
| [2019-04-18 17:11:33] |
In that case you need to set the Enable Debugging Output Input to Yes: Trading System Based on Alert Condition: Inputs And determine what the problem is when you expect an order to be submitted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-18 17:13:18
