Date/Time: Thu, 22 Oct 2026 12:19:55 +0000
sometimes have to click twice to select chartbook under new tab system
View Count: 1171
| [2019-04-17 07:14:13] |
| User753428 - Posts: 185 |
under the recently newly released tab system, many times when I click on a chartbook it doesn't switch to the chartbook. when i click it once or twice more, it will then switch to the selected chartbook. it might be hard to reproduce on your side since it doesn't always happen but it happens often enough to be very frustrating. |
| [2019-04-17 07:47:39] |
We will check on this.
| [2019-04-17 08:58:26] |
| User365411 - Posts: 196 |
rel 1902, Happens to me too, very annoying. Same behavior happen on the bottom labels when there are multiple charts in same chartbook. It seems that SC expect that you want move the label to a new position ( the red bar sometimes appear). Right-clik is immediate but not so useful like left clik, especially on bottom labels. Maybe a longer left clik delay applied to move label action can help. Date Time Of Last Edit: 2019-04-17 09:01:40
| [2019-04-17 10:19:43] |
We do already have this resolved and will have a new release out at the end of the day.
