Date/Time: Sat, 17 Oct 2026 06:51:42 +0000
Chart Settings: Volume at price multiple - POC of past periods changes
View Count: 1908
| [2019-04-17 03:40:42] |
| sierrasimon - Posts: 51 |
When I change the Chart Settings: Volume at price multiple from 1 to 2 (screenshot), the POC of yesterday changes to a very different price. In the scrennshots you can see that the POC of today changes 1 tick, what is normal, but the POC of yesterday changes too much. Why is that, and how can I fix it?
| [2019-04-17 18:53:22] |
Certainly the point of control will change. You just have to keep the Volume at Price Multiplier at 1 if you want complete accuracy with the point of control. There is no other possibility.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-17 18:53:50
| [2019-04-18 01:58:07] |
But It seems to be an error of programming, because the behavior of the POC of today while changing the Price Multiplier is logically, but of yesterday not. It´s quite important to change the multiplyer and still have the correct POC. Can you fix this error? |
| [2019-04-18 02:13:06] |
There definitely is not an error here. We do not have time to explain the details of why you see what you do under particular scenarios but certainly it can change.
