Date/Time: Thu, 19 Nov 2026 21:59:11 +0000
OpenGL Support and Historical Market Depth
View Count: 1270
| [2019-04-16 17:14:23] |
| User138602 - Posts: 185 |
Greetings, i am using version 1902 64-bit. https://www.sierrachart.com/SupportBoard.php?PostID=176848#P176848 If i understand the above linked post right, then you talk about implemented opengl boosts performance regarding tabs. I never had any problems with tabs performance and really dont understand the benefit at all. BUT for the last days i notice sluggish performance regarding Historical Market Depth charts. The whole chartbook gets kinda unresponsive. Will HMD charts eventually also benefit a huge opengl performance boost or should they already benefit? If planed, can you already estimate its ETA? Best Regards |
| [2019-04-16 17:47:37] |
First, let's start with the main issue you are dealing with - the Market Depth Historical Graph. Refer to the following for things you can do to help with the performance of the Market Depth Historical Graph: Market Depth Historical Graph: Improving Performance Second, with respect to the OpenGL support - this has not been released yet. We hope to have it out in the next 2 months. So just keep checking the posts to see when it is available. Third, the new main window tabs functionality is not related OpenGL. This was released late last week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
