Date/Time: Mon, 23 Nov 2026 12:22:07 +0000
Unable to Login
View Count: 1059
| [2019-04-16 09:12:07] |
| tarmmyy - Posts: 1 |
I am getting the following when I open SC http://www.sierrachart.com/image.php?Image=1555405800864.png |
| [2019-04-16 10:07:44] |
That does not tell us the underlying reason for the problem. See Section 9 here: CQG Trading Platform Service: Common Error Messages You will need your broker to help you with this since we do not know the username or password you should be using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
