Date/Time: Sun, 01 Nov 2026 23:51:29 +0000
show order fills on chart
View Count: 2022
| [2019-04-15 15:49:27] |
| User170575 - Posts: 221 |
Hi---when using the show order fills on charts---any idea what would cause longs to show up as shorts and vice versa? thx Cy |
| [2019-04-15 18:45:37] |
It sounds like you are referring to the colors of the Order Fills on the chart. Make sure the colors are set to what you expect. Refer to the documentation starting here and for the next 3 entries, for changing the color of the Order Fills: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trading Order Fill Buy Entry If the colors are set correctly, then refer to this particular section: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-04-15 19:59:15] |
thx---the issue appears to be an incorrect short position from a few days ago----when I go into the chart trade window--menu---settings--and enable--use order fill calc---the incorrect short position shows on the chart---does this data come from my trading service---which is interactive?
