Date/Time: Thu, 12 Nov 2026 21:49:42 +0000
Trade >> Customize Chart/Trade DOM Columns doesn't exist
View Count: 970
| [2019-04-15 09:27:04] |
| EdCarp - Posts: 25 |
On the page Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific), the page says to select the "Customize Chart/Trade DOM Columns" on the Trade menu. Unfortunately, this doesn't exist. Has it been moved to somewhere else? Thanks! |
| [2019-04-15 09:55:19] |
This is because Transact does not want you to have access to that.
