Date/Time: Fri, 16 Oct 2026 11:24:48 +0000
52 Week High/Low Study - WRONG Values
View Count: 1660
[2019-04-15 06:19:00]
HAB-User115006 - Posts: 38
I am trying to plot 2 lines to show 52 Week H/L of ESM19 continuous contract(Date Rule Rollover)
I am using the built-in 'Period OHLC-Variable Period' study
I am getting wrong values for 52 week High, and may have something to do with parameters I am using
If this is not the appropriate study do this please suggest any other simpler method
Settings are as follows:
I have hidden Open and Close values
Time period Type = Weeks
Time Period length = 52
Use current period = Yes
Number of days to calculate = 500
The correct value is the High value for 9/21/18, but the value is the High of 4/12/19
Screen shot of the chart is attached
http://www.sierrachart.com/image.php?Image=1555308970820.png
[2019-04-15 07:46:21]
User907968 - Posts: 885
Not used that particular study personally, but instead I use the one linked below, maybe this can help you?
Highest High/Lowest Low Over N Bars
[2019-04-15 07:56:32]
You need to use 1 Year for the Time Period Type and Length instead of 52 weeks.
