Date/Time: Fri, 16 Oct 2026 11:27:05 +0000
Removing Right Side Fill Space
View Count: 1202
[2019-04-15 03:50:03]
User997723 - Posts: 2
Followed the manual on removing the blank fill space to the right and it's all correct. I can't seem to adjust my chart to remove the fill space to the right without widening my print on screen. When I press the shift key and scroll the chart just stretches the footprint chart. Is there any way I can adjust so that my footprint chart so it's not so wide? I've attached two pics to compare. Please advise. Thank you.
Dennis
imageES FP Chart.PNG / V - Attached On 2019-04-15 03:49:14 UTC - Size: 52.54 KB - 506 views
imageES FP Chart2.PNG / V - Attached On 2019-04-15 03:49:22 UTC - Size: 52.69 KB - 433 views
