Date/Time: Thu, 12 Nov 2026 21:49:41 +0000
custom time periods problem if time starts at 9:30 am
View Count: 881
| [2019-04-15 02:42:21] |
| User954185 - Posts: 7 |
I have the 6 minutes chart for the hang seng futures starting at 9.30 am. (first session at 9:30 to 11:59:59 am) In the picture, the first bar is at 9:24 am. This is a problem. The first bar should start at 9.30 am. It has the same problem if I choose a 13 minute intraday chart. How do I fix this? THank you. |
Attachment Deleted. |
| [2019-04-15 09:22:05] |
Go into Chart >> Chart Settings and set the Session Times >> Start Time to 9:30:00 And disable the use of the Evening Session if you do not need that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
