Date/Time: Fri, 16 Oct 2026 11:26:45 +0000
[Programming Help] - Setting baseline for Histogram draw styles with ACSIL
View Count: 1182
[2019-04-14 23:00:34]
REKT4K - Posts: 8
Gday.
Is it possible to set a custom baseline with ACSIL?
For example, with Pine Sctipt on TradingView, they have a function histbase=, which can be used to draw histogram-styled studies with custom baseline. I.e. RSI/Stoch and other studies can be drawn with 50% level used as a baseline there - so, if RSI is above 50% - the histogram will be growing from 50 to 100; and if RSI is under 50% - the histo will drawn falling from 50 to 0.
How to implement this with ACSIL?
Thx.
