Date/Time: Sat, 28 Nov 2026 20:57:23 +0000
Trade Locations are being drawn wrong on the charts.
View Count: 1173
| [2019-04-13 16:13:34] |
| User176191 - Posts: 11 |
Hello I am using a 100 volume chart for execution and when I place my "show order fills" from the trade tab, they are in the wrong place. Anybody have any ideas how to fix it? Cheers http://www.sierrachart.com/image.php?Image=1555171979849.png |
| [2019-04-14 03:51:06] |
Refer to this section for this: Chart Trading and the Chart DOM: Misaligned Order Fill Markers on Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-04-15 15:59:23] |
I have tried that. My computer clock is set correctly. Any other ideas?
| [2019-04-15 17:38:49] |
How do you come to the conclusion that you are? The chart image you provided did not give any evidence of this. There were no order fills even displayed there. Your account is also expired. We do not provide support for expired accounts. You need to log into the support board with Help >> Support Board. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-15 17:49:37
