Date/Time: Fri, 16 Oct 2026 11:22:55 +0000
Market Depth Data from Previous Contract not showing
View Count: 1094
| [2019-04-12 21:02:21] |
| osaga - Posts: 53 |
Hello SC I'm trying to replay Sept. 3rd on the ES of last year (2018) and it needs to include market data so I can see the heat map. The problem is I can not get market depth data. I got the symbol set to F.US.EPU18 and Day to Load = 30 and Market Depth 30. This gives me chart data from Aug. 22 - Sept. 21, but no market depth data. I have included a screenshot of the chart settings. Appreciate the help. Best Regards |
| [2019-04-15 05:12:47] |
Most likely that is because you do not have market depth data for that day. Refer to: Market Depth Historical Graph: Market Depth Historical Graph Not Displaying Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
