Date/Time: Thu, 19 Nov 2026 21:59:11 +0000
[User Discussion] - Quote board layout
View Count: 1348
| [2019-04-12 03:09:10] |
| User28682 - Posts: 233 |
Is there a way to make a quote board have 2 sides of quotes, in other words side by side instead of one lengthy vertical one? Also, the volume in a quote board cell for any particular stock shows up as "9.84M". Is there a way to make volume the actual volume number? So 9,840,000 in the above instance. Date Time Of Last Edit: 2019-04-12 03:44:47
| [2019-04-15 15:49:11] |
No response???
| [2019-04-17 05:06:58] |
Neither of these items are supported. Both of these would be considered feature requests.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-17 05:07:26
