Date/Time: Thu, 05 Nov 2026 21:18:50 +0000
Chart Replay Customize speeds
View Count: 986
[2019-04-10 01:57:06]
User8600 - Posts: 10
Hi-
In the chart replay dialog box, some speeds are available as defaults such as 1x, 10x, 30720x etc.
Is it possible to customize the speeds that I want.
I need 1x, 5x, 10x, 15x and 30x only.
More than few times, software by mistake chose 15360x, when I was trying to type 15 for 15x speed and everything gets messed up.
I want to remove those higher speed settings from defaults and customize the list.
Possible?
Thanks.
image2019-04-09_21-49-42.png / V - Attached On 2019-04-10 01:53:44 UTC - Size: 22.65 KB - 330 views
[2019-04-10 18:04:49]
The replay window speed cannot be customized but we added the 15 times speed.
