Date/Time: Wed, 07 Oct 2026 04:05:47 +0000
Backups Folder Bloat - scss etc
View Count: 1081
[2019-04-10 00:19:59]
User14953 - Posts: 268
My SierraChart Backups folder seems large at 1.6 gb. How can I set that to a smaller number of copies, like maybe 3 to 5 or so instead of the current 31 or so? Thanks.
Date Time Of Last Edit: 2019-04-10 00:28:13
[2019-04-10 01:53:05]
This is not controllable. Just delete the older files that are no longer needed. At some point we will add some sort of automatic management for that folder.
[2019-04-10 02:25:02]
Kiwi - Posts: 375
If you don't want to get rid of them completely try compressing them with something like 7zip.
Compressing with 7zip produced a 230kB output from an 84MB Backups folder. Then delete the folder.
