Date/Time: Wed, 07 Oct 2026 04:05:50 +0000
TOS Data Feed
View Count: 1662
| [2019-04-09 18:04:47] |
| User836689 - Posts: 12 |
Hello, I wanted to confirm that the free Sierra Chart feed for trial users does not include live futures data? If this is correct, I would like to know if you can use the data feed from a ThinkOrSwim account? Appreciate your help and hope to hear from you soon. Thanks |
| [2019-04-09 18:17:30] |
Refer to this page: Is Historical and Real-time Data Included? You cannot use the futures data from Think or Swim. But you can use that account to authorize the data if using the Sierra Chart Exchange Data Feed for CME real-time futures data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
