Date/Time: Wed, 07 Oct 2026 04:06:49 +0000
[Programming Help] - how do i fix long and the short
View Count: 970
| [2019-04-08 16:13:17] |
| 1234567 - Posts: 42 |
Hey, I have trying to figure out, why on long trade keep going to short on the spreadsheet (K & L). It is supposed to stay long but it keeps going to short on the spreadsheet (K & L). I have look through the Sierra Documentation and no luck. so basically how do we fix this, the spreadsheet (K & L) to go long. And also how do I fix the spreadsheet ( M & N) into short. and yes I have looked all of the Serra Documentation Thank you |
Private File Private File |
| [2019-04-09 16:44:32] |
hey any help would be appreciated thank
| [2019-04-10 05:51:45] |
We are not completely understanding this. But it sounds like you may want to set this Spreadsheet System for Trading study Input to false: Automated Trading Management: AllowOppositeEntryWithOpposingPositionOrOrders Also refer to: Automated Trading Management: Troubleshooting Automated Trading System Behavior Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
