Date/Time: Sat, 28 Nov 2026 15:04:32 +0000
Changing display value format for a study
View Count: 1701
[2019-04-04 22:22:21]
User787032 - Posts: 39
When I plot my custom study on a chart, it outputs a calculated value below certain bars that meet pre-defined criteria. I notice that on my CL chart the study's output value has 2 decimal places, while on a GC chart it has 1 decimal place and on a EURUSD chart it has 5 decimal places.
I would like the calculated study value to be displayed with 2 decimal places on all charts. However, when I change the Value Format in the Study Settings window to .01 and Apply, it always reverts to the original price format.
Is there a way to set the value format for the study to 2 decimal places while leaving the price display format for the symbol unchanged?
[2019-04-05 18:29:19]
Does the custom study itself set the sc.ValueFormat?
If so, where in the study function is this done? Is it within sc.SetDefaults?
[2019-04-06 19:16:45]
Blue Brazilian - Posts: 42
Yes, it was in sc.SetDefaults. I thought that's where it should be, but I've moved it out of there now, and it works correctly.
Thanks.
[2019-04-06 19:49:01]
Yes it should be there. If it is in sc.SetDefaults, then you should not have a problem.
Date Time Of Last Edit: 2019-04-06 19:49:19
