Date/Time: Sat, 28 Nov 2026 15:04:32 +0000
[Solved] XBTUSD-BMEX: wrong daily volume
View Count: 1699
[2019-04-04 16:37:03]
User364630 - Posts: 13
Hi
The volume for 2019/04/02 and 2019/04/03 is wrong on historical D1 chart(i checked these 2 days only).
2019/04/01, 4091.0000000, 4144.5000000, 4036.5000000, 4132.5000000, 1194746674, 311434
2019/04/02, 4132.5000000, 5144.5000000, 4128.5000000, 4897.5000000, 580781122, 875206
2019/04/03, 4898.0000000, 5348.5000000, 4783.0000000, 4979.0000000, 897402514, 978062
2019/04/04, 4978.5000000, 5085.5000000, 4902.5000000, 4994.0000000, 2016528535, 441358
As you can see here
https://www.bitmex.com/app/trade/XBTUSD
correct would be
2019/04/02: ~5000000000
2019/04/03: ~5000000000
http://www.sierrachart.com/image.php?Image=1554395544571.png
I tried the steps for delete and download data a few times.
Thx
Date Time Of Last Edit: 2019-04-06 08:55:09
[2019-04-04 21:51:34]
Those volumes are calculated from the individual trades received in real time and recorded by our servers. Any data which BitMex is not transmitting would not be included.
[2019-04-06 08:50:23]
Ok, so why shows an intraday "1 Day" chart the correct volume for 2019/04/02 and 2019/04/03 then?
http://www.sierrachart.com/image.php?Image=15545400721000.png
Date Time Of Last Edit: 2019-04-06 08:52:49
[2019-04-07 00:52:56]
There are two problems. The historical daily data volume when it goes over the size of a 4 byte integer was not accurate. This is now resolved.
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
And in the case of an Intraday chart the volume may not be accurate either with very large volumes per bar and this will be improved upon in the next release.
