Date/Time: Thu, 08 Oct 2026 01:58:19 +0000
Order error Half tick price
View Count: 847
| [2019-03-29 16:56:34] |
| User708382 - Posts: 3 |
Hi, I keep getting this Order error and makes my trade mgmt software basically delete my stop orders. I have also gotten this error moving a stop manually. Order Error - OEC order update (Rejected). Text: Half tick price is not supported Other. Internal Order ID: 9409. Service Order ID: (none). Symbol: YMM19 | 2019-03-29 12:40:45 * Any Ideas? Thanks |
| [2019-03-29 17:16:39] |
Make sure the Tick Size in Chart >> Chart Settings is set to 1
