Date/Time: Thu, 08 Oct 2026 19:12:28 +0000
Server side OCO with CQG
View Count: 1894
| [2019-03-27 02:54:57] |
| ampjohnny - Posts: 13 |
Hello I just want to verify if server side OCO with AMP Futures using CQG data feed is supported and works correctly?
| [2019-03-27 04:02:06] |
Yes it does. Although it does have to be enabled: Global Trade Settings Windows: Use Server Side OCO Orders (if supported) (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
