Date/Time: Mon, 12 Oct 2026 07:22:22 +0000
sc.VolumeAtPriceMultiplier variable
View Count: 943
[2019-03-26 17:14:32]
User353585 - Posts: 69
I couldn't change the chart setting using the variable.
Reading value from the chart using the variable was OK.
Please check if it's something you can fix, thanks.
[2019-03-26 22:19:52]
This definitely works. sc.VolumeAtPriceMultiplier can be set to a different value and the chart will reload upon a changing of it and when the study function returns. This has been verified.
Date Time Of Last Edit: 2019-03-26 22:20:18
