Date/Time: Mon, 12 Oct 2026 07:22:35 +0000
Chart scale of duplicate chart tha has been unlinked
View Count: 1030
| [2019-03-26 14:22:04] |
| HinckleyBob - Posts: 45 |
Several prior issues explain how to duplicate a chart, unlink it, and change the symbol. Three charts were duplicated, unlinked, and relinked together. However, 1 of the three retains the scale of the original chart. I attempted a Scale reset ...page=doc/ChartMenu.html#ResetScale, with no change. The attachment shows the three charts, and the settings for the misbehaving chart lower right. How can I get the third chart to behave like the others? Thank you, Bob |
| [2019-03-26 22:28:52] |
Most likely the Scale settings are incorrect. Be sure that the scale is set to Automatic. Refer to the following for how to reset the scales for that chart: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-03-26 23:50:30] |
Correct, Fixed the problem. Thank you
