Date/Time: Thu, 26 Nov 2026 22:42:25 +0000
Spreadsheet // Excel
View Count: 1180
| [2019-03-25 17:10:20] |
| User581577 - Posts: 8 |
Hello, I would like to know if it's possible to import the data to excel ? (In real time) Thanks you for you help, Best regards |
| [2019-03-25 22:13:11] |
It is possible to access the Spreadsheet cell data from ACSIL, but you would need to figure out how to get that information into Excel. You will find some of the information on the Spreadsheet related functions starting here: ACSIL Interface Members - Functions: sc.GetSheetCellAsDouble() For general information about ACSIL, start here: Advanced Custom Study Interface and Language (ACSIL): Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-25 22:13:32
