Date/Time: Sun, 11 Oct 2026 16:48:25 +0000
Option Trading!
View Count: 1664
| [2019-03-25 15:56:41] |
| User454054 - Posts: 29 |
Hi, Can I trade the OPTION with my sierrachart? If yes, How to set up the chart for option trading? |
| [2019-03-26 01:37:10] |
We see you are using CQG, so refer to this particular section here: https://www.sierrachart.com/index.php?page=doc/CQGTrading.php#OptionsSymbolFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
