Date/Time: Thu, 26 Nov 2026 22:42:25 +0000
Updating to 64-bit SC
View Count: 964
| [2019-03-25 15:53:49] |
| Jabberwocky - Posts: 10 |
Hi, Is there an easy guide for updating from 32-bit to 64-bit SC? A few questions: Is a full uninstall (of 32-bit) and re-install (of 64-bit) necessary? If so, is it necessary to move data to a backup directory prior to uninstall? What other items must be changed? The website states ACSIL dll's must be renamed. Must they also be recompiled? Thank you, Jabberwocky |
| [2019-03-25 19:19:16] |
There's nothing special to do. The 64-bit version is already installed and you can run it using the 64-bit shortcut on your desktop. In regards to custom studies, if you are using those, refer to: How to Use an Advanced Custom Study or a Study Collection: Custom Study Not Listed or Not Displaying on Chart You do not need to rename any DLLs. You just need to make sure you have the 64-bit version of any custom studies you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-25 19:19:26
