Date/Time: Thu, 26 Nov 2026 22:42:25 +0000
Interactive Brokers Trial
View Count: 1028
[2019-03-25 15:44:28]
User109623 - Posts: 2
What is the difference between current setup adn this Real time data for US Stocks
I am in the same situation, I have AMP with CQG Fix data connection and I just want to have real time data for stocks, that's all.
Also, Is this datafeed better than Interactive Brokers feed? So I may not have the data differences between historical fill data and data from IB.
[2019-03-25 22:44:40]
Therefore you just need to use the Sierra Chart Exchange Data Feed. You can find the setup instructions here:
You will want to activate the US Equities Exchange and a real-time connection.
Yes it will be a better data feed than Interactive Brokers.
Date Time Of Last Edit: 2019-03-25 22:45:00
