Date/Time: Thu, 08 Oct 2026 01:55:36 +0000
Custom study visible in the list but not on charts
View Count: 1207
| [2019-03-25 15:20:48] |
| User657944 - Posts: 173 |
Hi Team do you have any similòar experience when a third party study is present in the Custom Study list but then is not visible on the charts? thx |
| [2019-03-27 18:27:41] |
HI can you please answer to my request? It's very strange I have this issue with a thir party software that is visible under custom study but does not work on the chart, I then get the source code and create the study my own and it works. thx Alberto Date Time Of Last Edit: 2019-03-27 19:03:33
| [2019-03-28 22:02:17] |
You really need to have the developer of this study debug the problem. We are not in a position to answer something like this. From our perspective we do not know what the problem is.
| [2019-03-28 22:34:11] |
| Ackin - Posts: 1865 |
Thank you for your answer. If I may react: Developer it´s me. User, the person who asked above use my package of free studies. I thought at first, that the problem was that there were 70 studies in package. I tried to create for him some individual library with only one study, with other versions of sierra. User always load the study but without function. When I send him source code and he himself compiled it in his PC, so the study is working. For me it´s interesting, because when you see my account, you can find, that my libraries are used more than 50 traders and they don´t have such problem. User doesn´t have classic Sierra but some interface over "TransAct" We will try to find solution between us. This thread could be closed. Best regards Date Time Of Last Edit: 2019-03-28 22:40:18
| [2019-03-29 03:45:51] |
Okay, still we do not know what the problem is. There can be hundreds of functions within a DLL. This is not going to cause a problem. We do not think it matters either if they are using Sierra Chart with Transact. That should not have any relevancy.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-29 03:46:10
| [2019-03-29 16:01:40] |
Thx Ackin and thx Sierra to anwer my post, it's very strange what is going on.
