Date/Time: Thu, 05 Nov 2026 21:26:57 +0000
ACTIVELY REFUSED CONNECTIONS (GAIN CAPITAL)
View Count: 1605
[2019-03-24 23:23:27]
ADRTvent - Posts: 23
sierra chart not connecting to Gain capital DTS service, please advise !!!! error saying computer actively refused the connections. please advise
Reading Internal Order ID file. | 2019-03-24 18:57:03
Reading Trade Orders file. | 2019-03-24 18:57:03
Reading Trade Positions file. | 2019-03-24 18:57:03
Account Balance file. | 2019-03-24 18:57:03
UDPListener (1340). Port 22904 | Listening on UDP port 22904. | 2019-03-24 18:57:03
Software version: 1882 64-bit | 2019-03-24 18:57:03
Usage end date: 2019-04-09 | 2019-03-24 18:57:03
Enabled for: Advanced Features. | 2019-03-24 18:57:03
Enabled for: Sierra Chart Historical Data Service. | 2019-03-24 18:57:03
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-03-24 18:57:03
Current selected Data/Trading service: GAIN Capital/OEC | 2019-03-24 18:57:03
Chart Update Interval: 500 | 2019-03-24 18:57:03
Intraday Data Storage Time Unit: 1 | 2019-03-24 18:57:03
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-03-24 18:57:03
2019-03-24 18:57:03 Local computer time | 2019-03-24 18:57:03
2019-03-24 22:57:03 Local computer time in UTC | 2019-03-24 18:57:03
2019-03-24 18:57:03 Local computer time in SC Time Zone | 2019-03-24 18:57:03
2019-03-24 22:57:02 Server time in UTC | 2019-03-24 18:57:03
Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-03-24 18:57:03
Program path: C:\SierraChart\ | 2019-03-24 18:57:03
Data Files path: C:\SierraChart\Data\ | 2019-03-24 18:57:03
OS Version Number: 10.0 | 2019-03-24 18:57:03
Locale Setting: C | 2019-03-24 18:57:03
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-03-24 18:57:03
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2019-03-24 18:57:03
Checking for new symbol settings. Requested symbol settings MD5 for service code oec. Request ID: 1. | 2019-03-24 18:57:03
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 46.4.97.203. | 2019-03-24 18:57:03
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 18:57:03
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-03-24 18:57:03
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-03-24 18:57:03
Received 5 login tokens. | 2019-03-24 18:57:04
Symbol settings MD5 received. Request ID: 1. | 2019-03-24 18:57:04
Symbol settings are up-to-date for oec. | 2019-03-24 18:57:04
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-03-24 18:57:04
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. | 2019-03-24 18:57:04
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-03-24 18:57:04
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-03-24 18:57:04
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2019-03-24 18:57:04
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed. | 2019-03-24 18:57:04
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-03-24 18:57:05
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-03-24 18:57:05
Error getting list of user files to download. Response: ERROR: Downloading of files on startup is disabled | HTTP status: Request completed with the HTTP response status code 200. | 2019-03-24 18:57:06
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 18:57:06
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-03-24 18:57:06
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-03-24 18:57:06
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 18:57:09
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 18:57:09
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2019-03-24 18:57:09
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 18:57:09
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 18:57:09
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 18:57:09
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 18:57:09
GAIN Capital FAST Data socket (2) | Connecting to IP: 64.94.37.222. | 2019-03-24 18:57:09
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 18:57:16 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 18:57:16
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 18:57:16
Service connection timed out. Will disconnect and retry. | 2019-03-24 18:58:09 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 18:58:09
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 18:58:09
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 18:58:09
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 18:58:09
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 18:58:09
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 18:58:09
GAIN Capital/OEC | Disconnected. | 2019-03-24 18:58:09
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 18:58:09
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 18:58:09
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 18:58:09
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 18:58:09
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 18:58:09
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 18:58:12
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 18:58:12
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2019-03-24 18:58:12
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 18:58:12
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 18:58:12
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 18:58:12
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 18:58:12
GAIN Capital FAST Data socket (2) | Connecting to IP: 64.94.37.222. | 2019-03-24 18:58:12
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 18:58:19 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 18:58:19
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 18:58:19
Service connection timed out. Will disconnect and retry. | 2019-03-24 18:59:12 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 18:59:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 18:59:12
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 18:59:12
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 18:59:12
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 18:59:12
GAIN Capital/OEC | Disconnected. | 2019-03-24 18:59:12
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 18:59:12
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 18:59:12
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 18:59:12
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 18:59:12
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 18:59:12
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 18:59:12
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 18:59:15
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 18:59:15
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2019-03-24 18:59:15
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 18:59:15
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 18:59:15
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 18:59:15
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 18:59:15
GAIN Capital FAST Data socket (2) | Connecting to IP: 64.94.37.222. | 2019-03-24 18:59:15
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 18:59:22 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 18:59:22
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 18:59:22
File >> Disconnect selected. | 2019-03-24 18:59:53
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 18:59:53
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 18:59:53
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 18:59:53
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 18:59:53
GAIN Capital/OEC | Disconnected. | 2019-03-24 18:59:53
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 18:59:54
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 18:59:54
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 18:59:54
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 18:59:54
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 18:59:54
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 18:59:54
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 18:59:54
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 18:59:54
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 18:59:55
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 18:59:55
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 18:59:55
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 18:59:55
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:00:01 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:00:01
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:00:01
File >> Disconnect selected. | 2019-03-24 19:00:02
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:00:02
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:00:02
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:00:02
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:00:02
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:00:02
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:00:02
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:00:02
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:00:02
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:00:02
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:05:18
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:05:18
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:05:18
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:05:21
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:05:22
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:05:22
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:05:22
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:05:22
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:05:28 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:05:28
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:05:28
File >> Disconnect selected. | 2019-03-24 19:05:46
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:05:46
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:05:46
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:05:47
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:05:46
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:05:47
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:05:47
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:05:47
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:05:47
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:05:47
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:05:48
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:05:48
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:05:48
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:05:48
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:05:48
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:05:48
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:05:48
GAIN Capital FAST Data socket (2) | Connecting to IP: 64.94.37.222. | 2019-03-24 19:05:48
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:05:55 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:05:55
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:05:55
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:06:48 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:06:48
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:06:48
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:06:48
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:06:48
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:06:48
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:06:48
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:06:48
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:06:48
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:06:48
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:06:48
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:06:48
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:06:48
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:06:51
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:06:51
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:06:51
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:06:51
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:06:51
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:06:51
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:06:51
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:06:51
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:06:58 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:06:58
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:06:58
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:07:51 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:07:51
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:07:51
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:07:51
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:07:51
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:07:51
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:07:51
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:07:51
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:07:51
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:07:51
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:07:51
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:07:51
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:07:51
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:07:54
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:07:54
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:07:54
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:07:54
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:07:54
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:07:54
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:07:54
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:07:54
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:08:01 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:08:01
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:08:01
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:08:54 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:08:54
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:08:54
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:08:54
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:08:54
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:08:54
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:08:54
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:08:54
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:08:54
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:08:54
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:08:54
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:08:54
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:08:54
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:08:57
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:08:57
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:08:57
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:08:57
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:08:57
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:08:57
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:08:57
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:08:57
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:09:04 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:09:04
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:09:04
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:09:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:09:57
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:09:57
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:09:57
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:09:57
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:09:57
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:09:57
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:09:57
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:09:57
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:09:57
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:09:57
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:09:57
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:09:57
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:10:00
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:10:00
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:10:00
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:10:00
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:10:00
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:10:00
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:10:00
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:10:00
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:10:07 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:10:07
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:10:07
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:11:00 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:11:00
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:11:00
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:11:00
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:11:00
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:11:00
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:11:00
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:11:00
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:11:00
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:11:00
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:11:00
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:11:00
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:11:00
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:11:03
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2019-03-24 19:11:03
GAIN Capital FIX Trading socket (2) | Connecting to IP: 64.94.37.222. | 2019-03-24 19:11:03
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:11:03
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:11:03
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:11:03
GAIN Capital FAST Data socket (3) | Creating socket. | 2019-03-24 19:11:03
GAIN Capital FAST Data socket (3) | Connecting to IP: 64.94.37.222. | 2019-03-24 19:11:03
GAIN Capital FAST Data socket (3) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:11:10 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:11:10
GAIN Capital FAST Data socket (3) | Closed. | 2019-03-24 19:11:10
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:12:03 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:12:03
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:12:03
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:12:03
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:12:03
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:12:03
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. | 2019-03-24 19:12:03
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:12:03
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:12:03
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2019-03-24 19:12:03
GAIN Capital FIX Trading socket (2) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:12:03
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2019-03-24 19:12:03
GAIN Capital FIX Trading socket (2) | Closed. | 2019-03-24 19:12:03
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:12:06
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:12:06
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:12:06
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:12:06
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:12:06
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:12:06
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:12:06
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:12:06
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:12:13 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:12:13
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:12:13
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:13:06 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:13:06
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:13:06
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:13:06
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:13:06
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:13:06
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:13:06
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:13:06
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:13:06
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:13:06
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:13:06
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:13:06
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:13:06
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:13:09
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:13:09
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:13:09
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:13:09
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:13:09
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:13:09
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:13:09
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:13:09
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:13:16 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:13:16
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:13:16
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:14:09 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:14:09
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:14:09
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:14:09
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:14:09
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:14:09
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:14:09
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:14:09
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:14:09
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:14:09
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:14:09
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:14:09
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:14:09
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:14:12
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:14:12
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2019-03-24 19:14:12
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:14:12
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:14:12
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:14:12
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:14:12
GAIN Capital FAST Data socket (2) | Connecting to IP: 64.94.37.222. | 2019-03-24 19:14:12
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:14:19 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:14:19
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:14:19
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:15:12 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:15:12
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:15:12
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:15:12
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:15:12
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:15:12
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:15:12
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:15:12
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:15:12
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:15:12
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:15:12
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:15:12
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:15:12
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:15:15
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:15:15
GAIN Capital FIX Trading socket (1) | Connecting to IP: 64.94.37.222. | 2019-03-24 19:15:15
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:15:15
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:15:15
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:15:15
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:15:15
GAIN Capital FAST Data socket (2) | Connecting to IP: 64.94.37.222. | 2019-03-24 19:15:15
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:15:22 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:15:22
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:15:22
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:16:15 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:16:15
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:16:15
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:16:15
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:16:15
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:16:15
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:16:15
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:16:15
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:16:15
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:16:15
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:16:15
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:16:15
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:16:15
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:16:18
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:16:18
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:16:18
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:16:18
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:16:18
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:16:18
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:16:18
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:16:18
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:16:25 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:16:25
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:16:25
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:17:18 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:17:18
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:17:18
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:17:18
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:17:18
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:17:18
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:17:18
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:17:18
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:17:18
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:17:18
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:17:18
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:17:18
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:17:18
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:17:21
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:17:21
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:17:21
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:17:21
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:17:21
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:17:21
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:17:21
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:17:21
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:17:28 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:17:28
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:17:28
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:18:21 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:18:21
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:18:21
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:18:21
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:18:21
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:18:21
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:18:21
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:18:21
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:18:21
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:18:21
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:18:21
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:18:21
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:18:21
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:18:24
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:18:24
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:18:24
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:18:24
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:18:24
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:18:24
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:18:24
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:18:24
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:18:31 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:18:31
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:18:31
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:19:04
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:19:04
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:19:04
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:19:04
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:19:04
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:19:04
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:19:04
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:19:04
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:19:04
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:19:04
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:19:07
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:19:07
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:19:07
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:19:08
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:19:08
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:19:08
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:19:08
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:19:08
GAIN Capital FIX Trading: Received a Logout message. Text = Invalid user name or password | 2019-03-24 19:19:08
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2019-03-24 19:19:08
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:19:08
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:19:08
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:19:08
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:19:08
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:19:08
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:19:08
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:19:08
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-03-24 19:19:08
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:19:08
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:19:33
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:19:33
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:19:33
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:19:33
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:19:33
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:19:33
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:19:33
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:19:33
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:19:40 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:19:40
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:19:40
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:20:33 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:20:33
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:20:33
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:20:33
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:20:33
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:20:33
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:20:33
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:20:33
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:20:33
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:20:33
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:20:33
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:20:33
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:20:33
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:20:36
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:20:36
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:20:36
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:20:36
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:20:36
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:20:36
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:20:36
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:20:36
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:20:43 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:20:43
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:20:43
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:21:36 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:21:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:21:36
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:21:36
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:21:36
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:21:36
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:21:36
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:21:36
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:21:36
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:21:36
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:21:36
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:21:36
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:21:36
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:21:39
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:21:39
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:21:39
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:21:39
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:21:39
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:21:39
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:21:39
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:21:39
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:21:46 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:21:46
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:21:46
Service connection timed out. Will disconnect and retry. | 2019-03-24 19:22:39 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-03-24 19:22:39
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:22:39
GAIN Capital FIX Trading: DisconnectFIX called. | 2019-03-24 19:22:39
GAIN Capital FIX Trading: Sending a Logout message. | 2019-03-24 19:22:39
GAIN Capital/OEC | Disconnected from the trading server. | 2019-03-24 19:22:39
GAIN Capital/OEC | Disconnected. | 2019-03-24 19:22:39
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-03-24 19:22:39
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. | 2019-03-24 19:22:39
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2019-03-24 19:22:39
GAIN Capital FIX Trading socket (1) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:22:39
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2019-03-24 19:22:39
GAIN Capital FIX Trading socket (1) | Closed. | 2019-03-24 19:22:39
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2019-03-24 19:22:42
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2019-03-24 19:22:42
GAIN Capital FIX Trading socket (1) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:22:42
GAIN Capital FIX Trading: Sending the Logon message. | 2019-03-24 19:22:42
GAIN Capital FIX Trading | Connected to trading server. | 2019-03-24 19:22:42
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2019-03-24 19:22:42
GAIN Capital FAST Data socket (2) | Creating socket. | 2019-03-24 19:22:42
GAIN Capital FAST Data socket (2) | Connecting to IP: 67.23.52.47. | 2019-03-24 19:22:42
GAIN Capital FAST Data socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-03-24 19:22:49 *
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2019-03-24 19:22:49
GAIN Capital FAST Data socket (2) | Closed. | 2019-03-24 19:22:49
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2019-03-24 19:22:53
The message log has been sent to support. | 2019-03-24 19:22:53 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 46.4.97.203. | 2019-03-24 19:22:53
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2019-03-24 19:22:55
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close. | 2019-03-24 19:22:55
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2019-03-24 19:22:55
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Closed. | 2019-03-24 19:22:55
[2019-03-24 23:32:08]
User81282 - Posts: 7
I am having the same issue with Gain Capital not connecting to SierraChart
[2019-03-24 23:39:48]
User75002 - Posts: 117
I am having the same problem. Gain probably needs to reboot their FIX server as the regular gain platform is working. This is probably not an SC issue, but maybe they can contact Gain about it.
[2019-03-24 23:59:20]
We are aware of a problem with the Gain Capital FAST market data server and we have communicated to them about this issue already.
[2019-03-25 02:45:08]
have there been any updates from GAIN Capital? Their trade desk and customer service was not aware of any issue. please advise
[2019-03-25 10:57:31]
Yes they have resolved it.
