Date/Time: Thu, 05 Nov 2026 21:17:46 +0000
keyboard shortcuts in replay mode
View Count: 1322
| [2019-03-24 22:06:41] |
| User873570 - Posts: 27 |
Hi, When I am doing replay mode, should I expect my keyboard shortcuts for trade actions to work? Currently, they do not. Thank you. |
| [2019-03-25 04:41:42] |
They should. Check the Window >> Message Log if there are any error messages related to keyboard shortcuts when you use them.
