Date/Time: Thu, 05 Nov 2026 21:17:42 +0000
sheets in spreadsheet duplicated by SC after restart
View Count: 983
| [2019-03-24 20:51:41] |
| Chad - Posts: 247 |
I have the Default Spreadsheet System for Trading Study applied to four charts in a chartbook. I renamed each from 'Sheet1' etc. to its market symbol for easier look-up. After updating SC to latest version (it shows as v1882), a 'Save All', application exit, and restart, I re-opened this chartbook, and there are duplicates of 3/4 sheets but named 'Sheet1', 'Sheet3' & 'Sheet4'. My original, re-named Sheets are still there as well. Did I do something wrong, or just a small bug? I'll leave them in the interim, but presume I can just delete the duplicate sheets. |
| [2019-03-24 21:18:02] |
You need to change the Sheet Name through this Spreadsheet study Input as well to match what you have actually changed the sheet names to: Spreadsheet Study Inputs: Chart Data Output Sheet Name Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
