Date/Time: Thu, 05 Nov 2026 21:27:00 +0000
drawing custom bar
View Count: 905
| [2019-03-24 20:14:18] |
| arruga - Posts: 253 |
hi I created various custom shortcuts which are all visible while I got my laptop plugged to my large screen When I take my laptop off, a few buttons are not visible as screen is smaller any way to scroll right or make them visible? |
| [2019-03-25 09:17:07] |
No, you just have to add an additional Control Bar for these buttons which can also be attached to the top, left, right or bottom.
