Date/Time: Sat, 24 Oct 2026 12:57:16 +0000
sudden trade log issue
View Count: 883
| [2019-03-23 02:01:44] |
| User917679 - Posts: 76 |
Out of nowhere I now have this trade log issue start on me in the latter half of today - I've made no software upgrades or anything; my totals are suddenly not tallying properly.. the gross profit remains zero, and the profit column is totaling negative in strange small increments... I tried upgrading to the latest version and then NOTHING worked(everything registered "0.00"). I have since rolled it back to 1885 and am left with the same problem |
| [2019-03-23 04:18:15] |
The first thing to do is at the top left of the Trade Activity Log, you need to go to the Trade Activity tab to do this, is to select "Fills" instead of Orders.
| [2019-03-23 12:33:02] |
I've since figured out that this is simply the commissions tallying up; the win rate, gross profit etc seem to remain unused.. I changed the setting to fills and it still gives the same issue thus far Edit: I switched the P/L format to "points" and now its displaying more like how it was before I had issues(I'm using ver.1885 btw). The commissions tally doesn't seem to show correctly when tacking it onto the points total, but this is alright enough for me Date Time Of Last Edit: 2019-03-24 00:09:00
