Date/Time: Sat, 24 Oct 2026 12:57:34 +0000
[Programming Help] - Getting a #value! error...
View Count: 890
| [2019-03-22 15:08:27] |
| User917679 - Posts: 76 |
I put this simple piece of code through my spreadsheet..: AND(ID25.SG1@4:ID25.SG1@29>ID25.SG4@4:ID25.SG4@29,ID51.SG1@4:ID51.SG1@29>ID51.SG4@4:ID51.SG4@29,ID68.SG1@4:ID68.SG1@29>ID68.SG4@4:ID68.SG4@29) From this alone(maybe spreadsheet settings too idk), is it possible to determine what could be the cause of a #value error here? Edit: I tried to make my code more efficient(as opposed to writing everything out full form), and it seems that the range function I'm using is incompatible with "AND()" ? In this case I'm abbreviating: // Heiken-Ashi #1,#2, and #3 are to EACH show 26 red signals in a row before a sell open is issued Date Time Of Last Edit: 2019-03-22 22:36:42
| [2019-03-22 23:05:04] |
| Sawtooth - Posts: 4357 |
If the signals appear as 1 in the cells, you could use a formula like this: =AND(SUM(OFFSET(ID25.SG1@4,0,0,26,1))=26,SUM(OFFSET(ID51.SG1@4,0,0,26,1))=26,SUM(OFFSET(ID68.SG1@4,0,0,26,1))=26) This will be TRUE even if there are more than 26 in a row. |
