Date/Time: Thu, 19 Nov 2026 21:33:04 +0000
Study that continue to highlights liquidity (limit orders) at all price levels
View Count: 2751
| [2019-03-22 10:25:36] |
| User860287 - Posts: 2 |
Good day, Regarding the Market Depth Historical Graph study, is it possible to set it to continue to highlight the liquidity (limit orders) at previous higher or lower price levels till it gets updated or intersected and not only at the immediate market depth levels? I've attached a picture. If not and if a customised study is required, which study do you suggest? Thank you |
| [2019-03-22 17:44:32] |
No, this is not supported. You can access the data with ACSIL and do with it what you require: ACSIL Interface Members - Historical Market Depth Data (c_ACSILDepthBars) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-22 17:46:41
