Date/Time: Sat, 24 Oct 2026 12:58:26 +0000
summary window
View Count: 891
| [2019-03-22 03:42:54] |
| User420296 - Posts: 12 |
Greetings, Is it possible to code a window, something akin to Chart Values for Tools but one that is custom that would hold statistical or summary data gathered from a study? Thanks |
| [2019-03-22 07:21:59] |
You can use the Study Summary window to display the values from the Study Subgraphs which can hold the statistical and summary data from your custom study: Study Summary Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
