Date/Time: Sat, 24 Oct 2026 12:58:21 +0000
Emulating
View Count: 902
[2019-03-22 02:45:09]
EdCarp - Posts: 25
Is there a way to "Delete All Data And Download" (from the Edit menu) in ACSIL? I looked through the list of ACSIL functions, but I didn't see anything that would delete the existing data, it would just reload the data from the existing file. Alternately, should I just rebuild the file name from sc.Symbol, call unlink() to delete the file, and then call sc.RecalculateChart()?
Thanks!
[2019-03-22 07:20:33]
You just need to use this function:
ACSIL Interface Members - Functions: sc.StartDownloadHistoricalData()
In the next release it will also support downloading Intraday data.
