Date/Time: Thu, 05 Nov 2026 21:17:33 +0000
Build Custom Studies DLL window disappears
View Count: 1048
| [2019-03-21 18:51:09] |
| User972768 - Posts: 166 |
Hello, There seems to be an issue with Analysis >> Build Custom Studies DLL window under v1882. If I open it via menu and then hit ESC it disappears, but then nothing can bring it back. The only solution I found is to restart Sierra, which is kind of overkill for such purpose. I checked behaviour of the Trade >> Trade Orders and Positions. I can open it via menu, then hit ESC and reopen it again via menu. Could you please take a look at this issue? Thanks and best regards Date Time Of Last Edit: 2019-03-21 19:58:16
| [2019-03-21 22:12:25] |
We will resolve this.
| [2019-03-21 23:02:45] |
We have this now resolved and we will have a new revision out later this evening.
| [2019-03-21 23:07:47] |
Thanks a LOT for very quick resolution
