Date/Time: Thu, 26 Nov 2026 22:42:25 +0000
ALERTS ON USER DRAWN TREND LINES (RAYS)
View Count: 1774
| [2019-03-20 17:02:51] |
| User901353 - Posts: 26 |
I HAVE FOLLOWED THE DOCUMENTATION PROVIDED IN CONFIGURING AN ALERT IN THE MAIN CHART ALERT SECTION. I GET NO ALERTS. IS THERE A LIMITATION TO THE USER PROVIDED DRAWINGS WHICH CAN BE USED FOR GENERATING ALERTS? THANKS, BOB |
| [2019-03-21 17:40:52] |
There was talk about pay for support a few months ago. Would this sort of ticket / request fall under that category? If so what would the charge be for information on making this work? Thanks |
| [2019-03-21 18:44:28] |
What is the alert formula you are using?
| [2019-03-21 19:33:13] |
CROSSFROMBELOW (C, UDID (4)) AND / OR CROSSFROMABOVE (C, UDID (4)) .....AND i HAVE TRIED IT IN THE CHART'S ALERTS SETTINGS AS WELL AS IN THE ALERTS SECTION OF STUDIES. i HAVE USED ID0.SG1 FOR PRICE AND I HAVE ALSO TRIED INCLUDING ANCHOR POINTS. THANKS |
| [2019-03-21 19:34:40] |
Where UDID 4 is the Line ID in the Ray's properties.
| [2019-03-22 19:24:15] |
The question was answered by Tomgilb. No need for help from Support. Thanks, Tom!
| [2019-03-25 19:12:06] |
At the current time it is not possible to use one of these CROSS functions and reference a chart drawing on the chart. You are also not referencing the drawing properly. For the documentation, refer to: Study/Chart Alerts And Scanning: Referencing Chart Drawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
