Date/Time: Sat, 24 Oct 2026 12:59:04 +0000
replay not working
View Count: 1364
| [2019-03-19 03:15:06] |
| CAACAP - Posts: 51 |
I am still not able to get a chartbook to replay accurately when using the start date checkbox none of the charts in the chartbook start at the same date. And on replay of chart DOM the bid/ask isnt replayed even though im recording the depth history. i can only replay depth that is in focus in the chart book
Date Time Of Last Edit: 2019-03-19 09:12:27
| [2019-03-20 03:38:05] |
What is the speed of the replay and how long do the charts take to load? Do you have Skip Empty Periods enabled on the replay window?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-20 03:38:52
| [2019-03-22 09:12:15] |
speed is 1 its almost immediate for some charts and takes about 1 minute for some others. Yes Skip empty periods is enabled. I found a way to get all them to play the same date which is to manually move each chart to the same time but there is a option to do it automatically that doesn't seem to work.
| [2019-03-22 18:26:06] |
You should not have to do that. See if you notice any difference when you uncheck Skip Empty Records.
| [2019-03-23 04:30:39] |
no still all playing different dates. Also still not showing market depth
Date Time Of Last Edit: 2019-03-23 04:36:31
