Date/Time: Sat, 03 Oct 2026 15:44:02 +0000
Dom // Colored only negotiated prices
View Count: 1000
| [2019-03-18 18:11:20] |
| User581577 - Posts: 8 |
Hello, I am looking for a feature on the DOM. I found on the forum a person making the same request, but I did not find the answer. I wish to color only the price traded on the dom. In attachment you will find the request. Is it possible? I thank you in advance for you help, Best regards, |
| [2019-03-18 23:14:05] |
No, this is not supported. However, there are daily high and low lines which can be added to the Trading DOM. Refer to: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM For the particular setting, refer to: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Daily High Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-18 23:42:06
| [2019-03-19 00:13:58] |
Thanks you for you message. Do you think there will be a solution soon? I know it's a detail but it makes it easier to read on the order book Thx |
