Date/Time: Sat, 03 Oct 2026 15:44:44 +0000
Volume By Price study from DOM
View Count: 1564
[2019-03-18 13:12:06]
User176191 - Posts: 11
Hello, Is there a way to move the volume by price study to the right hand side of the DOM because my trade orders are covering the total volume trading at price?
Regards
imageScreenshot 2019-03-18 13.07.07.png / V - Attached On 2019-03-18 13:09:05 UTC - Size: 217.86 KB - 494 views
[2019-03-18 19:37:40]
It is not supported to display information on the Right side of the DOM.
But, there are a few options available to you in terms of how the information is displayed. You will just have to try these options to see which you like best.
First, you currently have the Volume by Price study right-aligned. You can set it to be displayed to the left instead. Refer to this setting:
Volume By Price Study: Right Align Volume Bars
Second, you can display the Trade lines to the left instead. Refer to the following setting and the 2 above it:
Chart Settings: Align Trade Drawings Text to Right (Chart >> Chart Settings >> Trading menu)
