Date/Time: Sat, 10 Oct 2026 12:55:24 +0000
Alerts while off-line
View Count: 2308
| [2019-03-17 16:05:23] |
| User264760 - Posts: 6 |
Hi, I did a bit of testing with alerts sent on my e-mail adress. Everything works fine and I get the notification on my phone by e-mail when an alert is triggered. I use simple alert conditions like price level crosses. No coding or anything. I also tested this when my SC plateform was shut down, or disconnected from the internet. Result was no alerts, so I figured it was a client side system that requires my station to be running and connected all time. Simply put: Is there a way to get e-mail alerts while SC is off-line or not? Is there a workaround? Many thanks, Guillaume |
| [2019-03-17 16:43:03] |
| ForgivingComputers.com - Posts: 1239 |
I also tested this when my SC platform was shut down, or disconnected from the internet. Result was no alerts, so I figured it was a client side system that requires my station to be running and connected all time.
I think you hit the nail on the head. |
| [2019-03-17 19:53:56] |
No you do have to keep Sierra Chart running.
